666 بازدید
سلام و وقتتون بخیر
ما چند وقته ماژول پایانه فروش رو داریم و چند تا هم تراکنش زدیک که به وضعیت ارسال شده رسیدن.
اما چون بعضی قسمت‌هاشو اشتباه زده بودیم حذف نصب کردیم تا اطلاعات ریست بشن و دوباره نصب کنیم.
اما حالا وقتی نصب می‌کنیم ارور پایین رو میده:
Odoo Server Error
Traceback (most recent call last):
File "/opt/odoo/odoo14.0/odoo/tools/convert.py", line 677, in _tag_root
f(rec)
File "/opt/odoo/odoo14.0/odoo/tools/convert.py", line 330, in _tag_function
_eval_xml(self, rec, env)
File "/opt/odoo/odoo14.0/odoo/tools/convert.py", line 201, in _eval_xml
return odoo.api.call_kw(model, method_name, args, kwargs)
File "/opt/odoo/odoo14.0/odoo/api.py", line 395, in call_kw
result = _call_kw_model(method, model, args, kwargs)
File "/opt/odoo/odoo14.0/odoo/api.py", line 368, in _call_kw_model
result = method(recs, *args, **kwargs)
File "/opt/odoo/odoo14.0/odoo/addons/point_of_sale/models/pos_config.py", line 662, in post_install_pos_localisation
pos_configs.setup_defaults(company)
File "/opt/odoo/odoo14.0/odoo/addons/point_of_sale/models/pos_config.py", line 672, in setup_defaults
self.generate_pos_journal(company)
File "/opt/odoo/odoo14.0/odoo/addons/point_of_sale/models/pos_config.py", line 704, in generate_pos_journal
pos_journal = self.env['account.journal'].create({
File "<decorator-gen-219>", line 2, in create
File "/opt/odoo/odoo14.0/odoo/api.py", line 326, in _model_create_single
return create(self, arg)
File "/opt/odoo/odoo14.0/odoo/addons/account_check_printing/models/account_journal.py", line 75, in create
rec = super(AccountJournal, self).create(vals)
File "<decorator-gen-179>", line 2, in create
File "/opt/odoo/odoo14.0/odoo/addons/account/models/account_journal.py", line 568, in create
journal = super(AccountJournal, self.with_context(mail_create_nolog=True)).create(vals)
File "<decorator-gen-141>", line 2, in create
File "/opt/odoo/odoo14.0/odoo/api.py", line 347, in _model_create_multi
return create(self, [arg])
File "/opt/odoo/odoo14.0/odoo/addons/mail/models/mail_thread.py", line 264, in create
threads = super(MailThread, self).create(vals_list)
File "<decorator-gen-64>", line 2, in create
File "/opt/odoo/odoo14.0/odoo/api.py", line 348, in _model_create_multi
File "/opt/odoo/odoo14.0/odoo/addons/base/models/ir_fields.py", line 534, in create
recs = super().create(vals_list)
File "<decorator-gen-13>", line 2, in create
File "/opt/odoo/odoo14.0/odoo/models.py", line 3876, in create
records = self._create(data_list)
File "/opt/odoo/odoo14.0/odoo/models.py", line 3982, in _create
cr.execute(query, params)
File "<decorator-gen-3>", line 2, in execute
File "/opt/odoo/odoo14.0/odoo/sql_db.py", line 101, in check
return f(self, *args, **kwargs)
File "/opt/odoo/odoo14.0/odoo/sql_db.py", line 298, in execute
res = self._obj.execute(query, params)
psycopg2.errors.UniqueViolation: duplicate key value violates unique constraint "account_journal_code_company_uniq"
DETAIL: Key (code, name, company_id)=(POSS, Point of Sale, 1) already exists.
The above exception was the direct cause of the following exception:
File "/opt/odoo/odoo14.0/odoo/addons/base/models/ir_http.py", line 237, in _dispatch
result = request.dispatch()
File "/opt/odoo/odoo14.0/odoo/http.py", line 683, in dispatch
result = self._call_function(**self.params)
File "/opt/odoo/odoo14.0/odoo/http.py", line 359, in _call_function
return checked_call(self.db, *args, **kwargs)
File "/opt/odoo/odoo14.0/odoo/service/model.py", line 94, in wrapper
return f(dbname, *args, **kwargs)
File "/opt/odoo/odoo14.0/odoo/http.py", line 347, in checked_call
result = self.endpoint(*a, **kw)
File "/opt/odoo/odoo14.0/odoo/http.py", line 912, in __call__
return self.method(*args, **kw)
File "/opt/odoo/odoo14.0/odoo/http.py", line 531, in response_wrap
response = f(*args, **kw)
File "/opt/odoo/odoo14.0/odoo/addons/web/controllers/main.py", line 1398, in call_button
action = self._call_kw(model, method, args, kwargs)
File "/opt/odoo/odoo14.0/odoo/addons/web/controllers/main.py", line 1386, in _call_kw
return call_kw(request.env[model], method, args, kwargs)
File "/opt/odoo/odoo14.0/odoo/api.py", line 399, in call_kw
result = _call_kw_multi(method, model, args, kwargs)
File "/opt/odoo/odoo14.0/odoo/api.py", line 386, in _call_kw_multi
File "<decorator-gen-71>", line 2, in button_immediate_install
File "/opt/odoo/odoo14.0/odoo/addons/base/models/ir_module.py", line 74, in check_and_log
return method(self, *args, **kwargs)
File "/opt/odoo/odoo14.0/odoo/addons/base/models/ir_module.py", line 475, in button_immediate_install
return self._button_immediate_function(type(self).button_install)
File "/opt/odoo/odoo14.0/odoo/addons/base/models/ir_module.py", line 593, in _button_immediate_function
modules.registry.Registry.new(self._cr.dbname, update_module=True)
File "/opt/odoo/odoo14.0/odoo/modules/registry.py", line 89, in new
odoo.modules.load_modules(registry._db, force_demo, status, update_module)
File "/opt/odoo/odoo14.0/odoo/modules/loading.py", line 459, in load_modules
processed_modules += load_marked_modules(cr, graph,
File "/opt/odoo/odoo14.0/odoo/modules/loading.py", line 347, in load_marked_modules
loaded, processed = load_module_graph(
File "/opt/odoo/odoo14.0/odoo/modules/loading.py", line 222, in load_module_graph
load_data(cr, idref, mode, kind='data', package=package)
File "/opt/odoo/odoo14.0/odoo/modules/loading.py", line 69, in load_data
tools.convert_file(cr, package.name, filename, idref, mode, noupdate, kind)
File "/opt/odoo/odoo14.0/odoo/tools/convert.py", line 733, in convert_file
convert_xml_import(cr, module, fp, idref, mode, noupdate)
File "/opt/odoo/odoo14.0/odoo/tools/convert.py", line 799, in convert_xml_import
obj.parse(doc.getroot())
File "/opt/odoo/odoo14.0/odoo/tools/convert.py", line 719, in parse
self._tag_root(de)
f(rec)
File "/opt/odoo/odoo14.0/odoo/tools/convert.py", line 681, in _tag_root
raise ParseError('while parsing %s:%s, near\n%s' % (
Exception
File "/opt/odoo/odoo14.0/odoo/http.py", line 639, in _handle_exception
return super(JsonRequest, self)._handle_exception(exception)
File "/opt/odoo/odoo14.0/odoo/http.py", line 315, in _handle_exception
raise exception.with_traceback(None) from new_cause
odoo.tools.convert.ParseError: while parsing /opt/odoo/odoo14.0/odoo/addons/point_of_sale/data/point_of_sale_data.xml:49, near
<function model="pos.config" name="post_install_pos_localisation"/>
